Gjac
Jan 07, 2020Explorer III
For a brand new 2020 MH I doubt there is anything wrong with it. A 31 ft class C is probably heavier especially if it has more slides than your previous V-10's. If you had a older 31 ft Class A you would have had almost 60 more HP compared to your newer MH. HP to weight ratio determines the performance. MH magazine sometimes posts 40-60 MPH times of the various new MH's. To check to see if anything is wrong with yours just see how many secs it takes you to go from 40-60 MPH and compare it to what the specs say. My guess if you are between 12-16 secs there is nothing wrong with your MH. Give yourself sometime in it before you make any modifications if you are still not happy with the performance once the warranty is over there are a number of things you can do.
