k9dad's avatar
k9dad
22.5 tires/air volume
I have 22.5 " tires on my 2011 Fleetwood Southwind. My portable home compressor is rated for 110 PSI. I took it to the place where I store the RV and attempted to put air in a few tires that were reading low.I like to keep 100 PSI in all 6 of my tires. The compressor would not handle it.In fact I lost some air in the tires. I called my son-in-law (mechanic) and was told "if the volume of the tire is greater then the compressor tank volume,the compressor would not put out enough "constant" PSI to put air in the tires". I guess this is the case. To make a real long story short,can anyone with 22.5" tires recommend a small portable compressor that will have the ability to put out 110 PSI into a 22.5" tire? I plan on going cross country in the late spring and will need to carry a compressor on board for obvious reasons.
