dubdub07 wrote:
Tire size is dictated by the tires size, not the rim size. A 275 is the same height regardless of rim size. A 19.5 will usually have a 245 tire and a 22.5 uses a 275. That is your difference in height. I can't see much of a difference other than your gearing is affected negatively with more diameter.
Will
Tire size specifications do not directly measuring outside diameter, nor sidewall height, though both are defined by it. A 275/80 R22.5 tire has a tread width of 275mm, an aspect ratio of 80% (the ratio of the width to the sidewall height), and an inside diameter of 22.5 inches. The overall diameter would be 22.5 inches plus twice 80% of 275mm, which works out to 39.8 inches once all the unit conversions are done. A 245/75 R19.5 would have an overall diameter of 34 inches, for comparison sake, about a 15% difference.
Tire sizes are rather strange in that they combine a metric measurement, a unitless ratio, and an imperial measure.
