93minnieWinnie's avatar
Aug 14, 2017
225/75 R16
My camper sways all over the road when traveling in moderate wind. I had the front end inspected and the steering dampener replaced. The tires are only 2 years old, but I'm wondering if replacing them now will help.
I have a 1994 Winnebago Minnie Winnie on a 93 Ford E350. The sticker in the door calls for LT225/75 R16D with a max psi cold limit of 50 on the front and 55 on the back.
The tires that I have now are Laufenn LT225/75 R16 load range E. The front tires are inflated to 75 on the front, and 55 on the back. The back tires tend to bulge on the bottoms if I am not parked on completely level ground. The front tires never seem to buldge, but are inflated way above the original ratings.
The tire walls on these tires give them a weight limit of 2470 lbs at 80psi. The door sticker demands a front GAWR of 4600 lbs, and a rear GAWR of 7810 lbs (GVWR 12200)
I am most concerned about safety. I have no desire to leave solid pavement or drive in the snow. I just want the most reliable and recommended tires that make sense to put on this camper. While it looks like the tires I have meet the weight ratings, I'm wondering what might be a better option.
Thanks!
  • The door sticker tells what the psi should be for a reason. Too mush air in the front tires causes wander and you are running 25 psi too much.
  • OK, the placard calls for 50/55 psi and you are running 75/55 psi.
    I would think that would cause the vehicle to be kind of sensitive to cross winds. Try lowering the front pressure in increments and see if that helps. I would start with 65/55.
    You might even consider raising the rear pressures.
