Grit_dog
Dec 18, 2022Trailblazer
mountaintraveler wrote:Grit dog wrote:
If the length “limit” you’re targeting is due to actual physical access limitations rather than mainstream public campground “rules” then I would think a Class C would be VERY limiting due to the long rear overhang poor departure angle and lowish ground clearance.
In other words I could hypothetically take your Corolla more places than a 25’ long Moho. Realistically as well.
Everything RV related is a compromise.
If you don’t like the lack of space in a 24’ then you may not like a TC but I don’t see either being limiting for one person to full time and explore in.
However if exploring is the priority like it appears, then a dually pickup with a 10’ ish single or double slide out camper on it will check the “exploring” box much better. Greater ground clearance, much better departure angle if you get the right camper, lots of extra storage if you get a crew cab and the ability to live in the camper for an extended period off the truck and have a passenger vehicle for getting out without folding up camp anytime you want or need to go somewhere.
Interesting that class C might be able to go to less places than Toyota sedan. It's not Corolla, it's Camry, which has quite a low clearance but it got me to a few places over rough roads. Class C RVs have higher clearance than Camry, normally, also one can install bigger tires, do some other stuff with suspension but I don't plan to.
I don't plan to go anywhere too wild in terms of road clearance.
I think class C without too much overhang should at least go where Camry can go - ?
(I know that TC with pickup would give me a lot more options as to where to go, but I mentioned I already considered this option and for many reasons it's not something I can go with)
This response shows that you can’t even conceptualize one of the most obvious limitations of a C. Now imagine your Car is twice as long, twice as wide and over twice as tall with an 8’ tail swing and you can’t see out the back windows.
Being brutally honest here, a vehicle that would require a DOT registration and drivers file to drive commercially is not in your wheelhouse. Save yourself and whomever you forget is next to you when you make that last turn into the campground some money
38,782 PostsLatest Activity: Aug 31, 2026
