bobndot
Dec 21, 2022Explorer III
mountaintraveler,
As long as you thought it thru and are comfortable. Knowing all the variables is where you want to be.
Just something to be aware of for people like us who go into the woods. When you are looking at rvs, pay attention to the dump valve location. On newer models, the dump plumbing is usually tucked up inside an exterior compartment. On older models, it's exposed and easier to hit it something. Ground clearance of that plumbing setup is less. If your rear wheels dip into a low spot on the trail, that plumbing may touch the ground.
RE: $3k. it was FYI. If you bought new towing equipment to outfit your car to tow it. I wasn't sure you were renting a dolly or not.
38,782 PostsLatest Activity: Aug 31, 2026
