mountaintraveler wrote:
pnichols wrote:
If I was a bit younger and much richer, I think I'd consider this - 19'8" long and AWD - probably install a bit taller tires on it for more ground clearance, though:
https://pleasureway.com/models/ontour20/
LOL 180K!
I grew up in a world where most roads were dirt (deep dirt, the kind that sinks army tanks) and camping was simple and inexpensive activity, in rough norther climate.
Look what they did to this now...And these are rapidly depreciating assets, costing as much as a house that is going to only appreciate (while one spends equal amount of money on regular maintenance)
They're going to force electric vehicles pretty soon, I'm sure, what's going to become of the value of these overpriced vans...when it'll be hard and very expensive to buy any fuel.
Class C and many class Bs are overbuilt and have too many "amenities" I have no use for. I don't need entertainment system/TV, on-board generator, 2nd sink, big bed, oven, multiple stove burners (need one), microwave, outside shower, dinette, can do without A/C and 6 gallon water heater (1 gal heater is fine with me, with 6 gal I just waste propane).
So it'd make sense to build something I want on my own, with own hands as they charge insane money for builds, or gut a small trailer to make more storage space. But I won't travel after this last big trip as want to settle into small farming life.
I don't need a generator except for emergency, my cheap solar panel meets all my needs. I have to run Onan on board generator every couple of weeks to avoid clogged carburetor, which gives me headache as I hate fumes, noise and have to set new altitude every time and my altitude switch is finicky, got to change to summer oil, have to worry about fuel varnishing and fuel quality for that expensive, picky generator - and I have to run electric heater outside, heating the forest to load that generator properly! I prefer my cheap 2nd carry-on dual fuel Pulsar generator, one kind of oil for all weather, and I only use propane - no fuel rot, no mess or smell, no exercising it. On-board Onan seems to require convoluted procedure to prepare it for storage, much more than draining the carbureator, so can't just keep it shut down.
Ann Cat ... since this is a Class C forum section ... what year/brand of Class C do you have?
My good old E450 based 2005 Itasca (Winnebago) 24 ft. Class C I bought new in 2006 came stock with all those "luxuries" that I guess you're saying you don't need. The DW and myself use them all when drycamping - whether drycamping in a campground or drycamping out on the far side of beyond.
We never drive through an entrance leading to the middle of nowhere without having first topped up our 55 gallon gasoline tank, which gives our built-in Onan genny plenty of run-time - in addition to what the V10 might need to get us back to civilization. I also carry along a portable genny along with it's own gas supply so as to provide coach battery charging backup - to either the Onan charging of the batteries (plus running all other electrical gadgets) or idling of the V10 to charge the batteries. I never adjust the Onan's altitude setting - just leave it on sea level all the time.
I maintain positive air pressure inside the coach whenever running either of the two generators or idling of the V10 - so as to use physics to absolutely keep out any/all fumes ... and it works like a champ.
It sure is nice to have inside or outside showers, perfect coach interior temperatures regardless of outside temps, plenty of refrigerator/freezer cubic footage, 3 stovetop burners if needed, an oven if needed, a large 12V fan with a long extension cord to blow on us when sitting outside under the awning in hot outside temps, a lounge chair for reading or watching of movies when not outside, large storage tanks, two queen size beds for complete sleeping comfort, 5 ways of recharging the coach batteries anytime anywhere (we don't have/need solar - yet) and higher-than-stock rough road clearance due to my use of tires with a larger diameter than what came stock on our Class C. All of this is supported via an overkill E450 chassis for added strength and durability that took me a long time to locate under a 24 ft. Class C ... which are usually built on only an E350 chassis.
The infuriating part is that all the above set us back only around $54K when we bought new back in the day. What a rip'off todays RV prices are!
