I have a 2018 Sunseeker 2350 by FR , 24 ft. Ford E450.
Being that it has a 14,500 gvwr and rolls down the road loaded at approx 12,500 expect it to ride hard until you load it up with full water etc.
** ‘They need to be properly aligned with a positive caster‘ .
I needed to install suspension upgrades to handle crosswinds and bow waves better but i would wait on those until the warranty expires and to really see if you need to do that.
Optional - Shocks, rear track bar, H. duty F and R sway bars .
I have a large storage area in the rear.
I dont like those plastic bins they use to hold gear. Keep an eye on all of them as you load them and use them. I don't trust them to carry too much weight.
I added oak cross members on top of bins which are supported by the solid wood edges that surround the bins. I placed wood planks on the cross supports that now holds my gear. The bins carry light stuff, they only use small screws and caulk to support those bins. Kind of flimsy.
Its had s 158” wb. which has a long rear overhang. The rear hitch has safety tabs welded onto it that act as scrapers to protect the rear overhang. I have to pull in forward into my driveway bc i scrape those tabs across my sidewalk if i back in. You need to know if you have clearance to park unless your street and driveway are relatively flat.
