Gjac wrote:
ron.dittmer wrote:
Gjac wrote:
Never realized that short C's had handling issues with a WB/L ratio of .54 of 54%. Mine is 52% and I drive it like my car with one hand even with trucks passing me. I notice most of the C's I looked at were as high as my A. I wonder if the height to length has more affect because of the higher CG. Do shorter C's feel tippy when cornering than say longer C's on the same chassis? ............just not sure of the corner bed and getting up 3 times a night to go to the bathroom, but everything is a trade off.
Any class C with a poor wheel base ratio (like we have) will not handle as well as one with a better ratio. Fortunately if your new rig has a "handling" problem, $1000-$3000 in aftermarket upgrades will get you satisfied.
You should have a much better chance with a brand new E350/E450 today than I did back in 2007, to have the rig handle well without that additional investment. I read somewhere that Ford is installing some of the aftermarket "equivalent" upgrades into the RV package of their new 2021 chassis with 7.3L-V8 engine. They got with the program installing heavy duty front and rear stabilizer bars. You might still have to invest in a rear trac bar or heavy duty steering stabilizer, but you are at a much better starting point. You might even find your new rig to handle just fine without further investment.
. Hi Ron, I must be missing something if you do the math a 24ft MH with a 158 in WB will have a WB/L ratio of .54 or 54% which is suppose to be good. So I don’t think poor handling of these shot MH’s is do to poor WB/L ratio. That is why I thought there must be something else causing poor handling like height to length or weight distribution or too much weight for the Ford chassis.
Our rig is surely "tail heavy" which takes weight off the front axle, thanks in-part to the wheel base.
Some time since, our specific rig became available on a Sprinter with a 170" wheel base. The Sprinter handled our model rig much better because of the longer wheel base that also distributed the weight better....more weight placed on the front axle.
