msmith1199 wrote:
GlennLever, you obviously know way more about electricity than me, but I do have a question based on the info you have posted. If the circuits are basically the same thing with the neutral and the ground eventually connected to each other, then what is the purpose at all in having two different types of plugs? Basically why is it that dryers and ranges and welders for some reason need a different plug than RV's? Is the four prong plug unique to just RV use, or are there other things that also use the four prong plug?
IVYLOG kind alluded to the reasoning behind four vs three.
Back in the day, and yes I am over 60, all houses had two prong outlets. One was the neutral and the other the hot.
The problem with that is a lot of the hand tools and kitchen appliances "grounded" the case and the case was metal. As the plug could be inserted into the wall outlet, you could end up holding a "hot" case. If you were doing that and touched a ground you could get electrocuted.
They then came up with one prong of the plug being larger than the other which would only let you plug the tool in one way, there by insuring the case was always ground.
They then came up with ground fault, I am not clear on the technology, but it senses if there is a potential difference between ground and neutral, and ground fault circuit breaker trip MUCH faster than a normal circuit breaker.
Why there are three prong stove and drier outlets, I do not know. That there are three prong outlets for running stoves and drier says something, but I am not sure what.
Do not do this if you are uncomfortable with it.
Goggle it and understand how it works.
(I have never seen a ground and neutral wire of different gauges in a modern cable)
