RobertL0
Apr 16, 2015Explorer
Buy an 5K btu AC and make a cheap flimsily bracket and put it in the emergency escape window. (5000 btu are the smallest and lightest they make, as a window unit). Run the power cord out the same window, connect to the pedestal, duct tape any openings.
Turn on additional 5K btu
Emergency escape? Push on the AC, it will fall to ground, bail out
AC about $125
Don't make a solution more complicated and expensive than they need to be
AC about $125
travelingcat wrote:
We are considering buying a Forest River Forester 3051S or 3011DS with a 15000 BTU air conditioner. It would be used for extended trips (2 to 3 months) to visit family between Florida and Houston, Texas. The fact that 30 amp limits us to only one air conditioner has us concerned. Is there anyone out there owning one of these or a similar size Class C and using it in this climate? If so, does the one air conditioner keep you comfortable? Thanks for any help you can give.
38,780 PostsLatest Activity: Jul 05, 2026
