zach477 wrote:
I know the bottom one is the 12 volt fuses. I posted it because I figured why not. Haha.
I won't be at a campground to try flipping the breakers for a couple of weeks. In the mean time I could try it while being powered by the generator. Will that give me the same results? I believe while running off the generator, one AC runs off the 30 amp power from the generator along with everything else, and the other runs off its own 20 amp circuit.
On Genset, the ECC is not activated. The rear AC runs off the 20 amp breaker on the genset and the rest of the RV runs off the 30 amp breaker on the Genset. So, I doubt you will get the same result as usually, they have a transfer box for the 20 amp genset to the rear AC. BUT, turn the Genset 20 amp breaker OFF and then you can do the test on Genset. Doug
