dogdiva's avatar
dogdiva
30 AMP SURGE GUARD
I have a 30 amp surge protector by Surge Guard...not the hardwired type
How can you tell if it is not working??
wHAT is the normal life span ?
It has something "loose in it" as when you shake it, it rattles, sounds like a little screw or something
Any info would be appreciated
Thanks
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have a test system but frankly I purchased it for other needs (Kind of expensive) but the unit performs multiple functions.. One is Spike supression and if it's more than 5 years old odds are that's not as good as it once was.. However you can easily add mnore spike supression.. (the devices providing are even easy to replace)
    The other functions are power line monitoring and high/low voltage cutoff. If hte LCD display is showing the voltage and current. then the monitoring is likely working. To test current requires a variable AC voltage source.. I have a small one (Good enough for testing) but odds are if the display displays the proper voltage plus or minus one volt (Compare to meter) then it's working.
  • It IS serviceable. Had the same problem with mine. When I called them, no help as was out of warranted. Asked if I could take it apart, the reply was " it's yours, do what you want with it!". So I took the back off, yes you can with some work. Found 3 of the bolts had come loose holding the relay and were ratteling around in side. Took some locktite and reattached the bolts. Lots of silicon when putting case back together. Still works great. They really need to use locktite in production, this seems to be a common problem.
  • Removed because I did not assume that the OP was a Do-It-Yourselfer.
    Randy
  • Surge Guard Instructions
    When you plug in the 'Power On' lights should be lit. (top 2 or 3 depending on model)
    Also bottom 'Surge' LED should be lit. If not ON then no surge protection
    No typical life span.......but only 1 yr. warranty (limited)
    Should NOT rattle. Unit is sealed and is NOT serviceable.
    Contact Surge Guard if less than 1 yr old (good luck with that)
    LINK
  • all the lights were on when I disconnected it as the plugs showed heat burns
