Ivylog
Feb 28, 2017Explorer III
I would use a tip that does not turn it down as much as all the diffuser does is spread the heat out so when it regenerates you hopefully to not catch the grass on fire or burn the asphalt. Cutting through the old piece and then bending it up and twisting it out is where you'll end up if it's rusted so much as to rust off. Good luck.
38,783 PostsLatest Activity: Sep 23, 2026
