I have a spliter that has 2 30 amp plugs that are wired to a 50 amp plug so I can plug into my motor home I was told that if I plug into 2 30 amp plug that I would get 50 amp to the RV? Has anyone ev...
2 30A plugs wired correctly to a 50A receptacle will allow you to run as if connected to a 50A receptacle provided the 2 30A plugs are inserted into 2 separate 30A receptacles. There is one potential issue. Any 240V appliances you have may or may not work depending on how the 2 30A receptacles are connected to the campground mains. EDIT: Each 30A receptacle must have its own circuit breaker.
