SCVJeff
Jul 07, 2017Explorer
OP: You mentioned turning on the fridge. You are running it on 120V or LP ? On really hot days I seriously doubt a 30A CB will support both compressors running AND the fridge on elect.
If you are maintaining 24A and the breaker still trips, consider changing it. The one I bought 2 weeks ago cost me less than $4 @ HD.
Also, I purposely installed it at the bottom of the panel so its not cramped in with other heat producers, and the breaker on top is typically a light load. Every little bit helps..
