Janss
Jul 08, 2017Explorer II
Thanks for the additional input. I think I'll change the breaker to start. I believe it already is in a good position...noting the various comments about getting as much air as possible (or away from as much heat from the other breakers as possible). And in the meantime investigate the voltage issue, taking notes from all your comments.
down home....Inside the MH, each air compressor has its own 20amp circuit breaker. I wish Winnebago had made this a 50AMP coach, but alas, it is only a 30AMP coach. We've always had to be careful about turning things on while a/c is running. But have always been able to run the frig with it...just not other stuff.
