jsmart
Jun 01, 2015Explorer
30A vs 50A
Just a curious question for all you experts out there, We have a 2002 32V Itasca Sunrise, bought it used, have had it almost 2 years. It has the 30 amp power cord, however, the box the power cord goe...
eXodusRV wrote:jerseyjim wrote:
The only thing 50 AMP does (vs 30 amp) is let you run BOTH a/c units at the same time. Those that say they run 2 units on 30 amps at the same time, are taking a chance with electrical overload and that can equal a fire. Run both on 20AMP? Hope a fire extinguisher is nearby. IMO a definite recipe for disaster. Again...my opinion.
I have no idea why any coach company would market a unit with 2 a/c units and give 30 amps. IMO (again) that is not only dangerous but stupid. But then, I've seen new units at RV shows with no electrical outlets in the kitchen! How dumb is that?
You do know what breakers are for ? Do you ?
In case you use more then 30A then the breaker trips and you will be there without power.
It's like in your house, you've got probably 5-10 15A outlets wired to the same 20A breaker. How often due houses burn down because of installed wiring ? rarely ever.
The wiring used for 30A is usually capable to supply double the amps for at least a couple of hours without getting dangerously warm. Most all RVs burn down because of defective cooling unit on Fridges.
