c5er
Feb 16, 2019Explorer
32 ft class c
So after looking at 27 foot class c’s the family declared the sun seeker 2500ts too small and like the 3010dsf which is a hair over 32ft. What are the disadvantages or concerns with going that long? ...
Rick Jay wrote:
Mich F,
For full disclosure, while your OCCC number looks good, from a CAT Scale slip you once posted on a different forum, you only have about 1,800 lbs. capacity on your rear axle. Almost 900 lbs. of your OCCC is unusable unless as rjstractor says, you hang a lot of stuff off the front bumper. (To piggyback onto rjs comments, when you put weight behind the rear axle, it not only adds it's weight to the rear axle, but the rear axle acts as a pivot point and it takes weight OFF of the front axle and transfers it to the rear axle too. Think of a see-saw.) A couple could probably live with that if they're careful about weight. But I think a family would be hard-pressed to keep it within the limits. But it really depends upon your intended use of the rig.
