Trackrig
May 05, 2013Explorer II
If the engines were mounted in the exact same MH I expect you wouldn't be able to tell the differance. I think the MHs they're mounted in will make more of a differance then that little bit of HP. Such as the differance in tires, air pressure, wheel bearing condition, rear end gear ratio, do they have the same transmission gearing, aerodynamics, weight, etc.
Bill
Bill
38,780 PostsLatest Activity: Mar 30, 2014
