enblethen
Jun 22, 2014Nomad
There is an idle air control valve on the right side of the throttle body near the manifold. This sort of acts like a choke. The valve can be clogged with carbon or the passage inside the throttle body can become clogged with carbon.
It is fairly easy to use some carb cleaner to clear passage and valve. Be very careful when removing the unit. It has two vary small screws that can break easily.
38,766 PostsLatest Activity: Jan 10, 2026
