SOMOS's avatar
SOMOS
Stalls While Driving
Hello Everyone!
I'm a new member and new to the RV Life. I recently purchased a 1991 E-350 (7.5L Engine). It has 62K miles. Runs great! However, on a recent trip it stalled (choked) while I was on the freeway, driving at approximately 60 MPH.
The AAA Driver came out and told he has seen this before. Apparently it happens when the fuel lines get so hot that the fuel becomes vapor (Vapor Lock) and therefore, the engine does not get fuel. He gave me the following advice:
Remove the gas cap. Let it cool and get on the road again. I did that and it worked just fine. However, this seems to happen regularly when the engine gets hot (Engine does not overheat). Every time, I let it cool down and then it starts and runs great until it happens again.
I've treated the gasoline with a Sea Foam Gasoline treatment but the problem remains. I've been told the fuel pump is going out. Others suggest replacing the fuel filter. The most recent suggestion is to replace the Ignition Control Module (ICM) and they are 90% certain this is the problem.
Anyone else experience this problem? Any suggestions for this newbie? Any advice will be greatly appreciated.
In gratitude,
Joe Silva
