ScottG
Jan 11, 2014Nomad
Take out the oil pump and take it apart. Check its gears for contamination and damage. I would pull the caps off several rods and mains and check the bearings (bushings?) for contamination. If you find anything in the bearings then the eng is done and needs a complete tear down. Anything less and you will have even more knocking down the road.
38,769 PostsLatest Activity: Dec 31, 2014
