trop-a-calExplorerJan 11, 2014454 Head back on engine started #7 piston noiseNow with full compression on both heads the 43,000 mile 1997 454 vortec has the same noise that it had prior to it shutting down completely. The noise was checked by removing spark plug wire and heari...Show More
DaveinetExplorerJan 11, 2014I assume the 8500 includes labor for the install. If not, you can buy a crate 502 for less.
Related ContentAchates opposed piston enginesPotential engine overheatingPiston Disintegrated End Of An EngineNear engine overheating gaugeStuck Caliper Piston
