K_Charles
Jan 11, 2014Explorer
You said you put the heads back on so you did the top end and not the bottom? If you got water in the cylinder you may have a bent food, did you check piston hight when you had the head off? Buy a crate motor and be done with it.
38,769 PostsLatest Activity: Apr 04, 2026
