JimM68
Jan 14, 2014Explorer
connecting rod bearings typically knock "at the top"
If you rev the engine briefly, the rod will clatter near the peak of the rpms and a lil on the downhill side.
A connecting rod knock = excessive clearance between the rod bearing and the crankshaft. the rod bearing may be worn to copper or worse, and the crank may be worn as well.
A "spun bearing" = the bearing shell has come loose in the rod, and moved. This will ALWAYS damage the crank.
38,769 PostsLatest Activity: Apr 03, 2026
