trop-a-cal's avatar
trop-a-cal
454 L29 1997 moves to next stage of repair
So the trouble started last September when a fill up in NJ, (55 gallons), yielded a pinging and suspected bad gas. Then with confirmation it was not the gas, and after idling with octane booster, the pinging and loss of power turned into a ticking. Then in route to home,(in Florida), a stop overnight in So. Carolina for the night and morning start there was a knocking. Full power going to home not hearing a knock but at idle. Oil changed and garage not wanting to work on engine I headed home 8 miles away and it shuts down a mile from home. Towed in for evaluation told it started with a new distributor gear as old one was worn down on one side. Being told it needs total new engine at $8500 +- I then had it towed for second evaluation. Right bank 1,3,5,7 compression was off in 3 & 5, so head came off and proved to be a leak at center point between 3 & 5. towing so far $650, (reimbursed from insurance),work $495. New garage bill for head check and new gaskets was $1069. Now upon restart the engine has tick again perhaps at 7 cylinder; hydraulic lifter or spun bearing still not confirmed. Garage has no lift and can't get interested in doing check, as another opinionated engine man says rod bad? Ticking not heard other than idle, so third opinion from a 21 year Chevy service manager, tomorrow. First opinion was block cracked turned out head gasket leaking, second opinion rod knocking. Two other opinions say lifter stuck with coolant in it. This unit is a 36 Foot 14 foot slide Tropical 235S 1997 with new $4700 roof, all new brakes, plus everything else in great condition as it has only 43,886 miles on it and I am original owner. Sticker new $108,500. current value with engine repaired maybe $17,500. as is maybe $3,000. so fix well worth doing if it's under value repaired. MORE TO FOLLOW....as work gets. done.
