Peg Leg wrote:
Probably the fuel pressure regulator. My 97 7.4 has over 220,000 mi on it and it's not been annoying enough to hassle with. It still has the original injectors. If you want to check the fuel pump relay just switch it with one of the other relays with the same numbers on top.
Have you had to replace the intake manifold gasket yet. Keep a eye on the coolant level. When the coolant level under the radiator cap starts staying about the same level as the top front passenger side of the block this will be the likely culprit. Some leak externally where you can spot some coolant that's leaked.
Very good strong motor, wish they still made them. It's still hard to get used the high RPM's on these new small blocks for me.
I'll try the relay swap you suggested, thanks. I do have to add coolant to it occasionally but I don't smell any coolant. Never have to add much, maybe just a qt. a couple times a year. I too like this engine. Plenty of grunt pulling my trailer over the mountains.
