Born To Travel wrote:
You can use Dex 6, as it is backwards compatible.. But it is at the lower level for viscosity, Meaning it is already as thin cold as Dex 3 is hot... Do you really want that in a engine compartment that runs as hot as the enclosed engine in an RV?.. I run Dex 3 in my 1995 4l80e in my RV..
From my previous post I don't want to run syn in an 18 year old trans with 99 k miles on it. I decided to go with the Super Tech(Dextron/Mercon) from Walmart that is compatible with Dextron 3, which was nowhere to be found in my area.
