GJax wrote:
I'm new to the forum. I am looking at getting out of a trailer and have an opportunity to get a 97' Damon Motorhome with the 5.9l 180hp Cummins, w/ Allison Trans on a Freightliner XC chassis. Has under 60k miles. The price seems right. I was looking to see if anyone has good or bad thoughts on this setup. I can't seem to find much info on regarding this set-up. I know the 5.9 isn't a powerhouse but I'd be towing a Ford Escape, about 4k lbs, so not a big load. I understand the Freightliner chassis is a plus. Most trips would be under 1500 miles, occasional mountain trip is possible. Any thoughts good or bad is appreciated.
I've also looked at the Class C's but seems most have the Ford V10 and I've read too many horror stories. They don't seem to get longevity on the engines and seem to have problems. Timing Belts and Valve problems when they get to about 100K
Nothing wrong with the V10 and with a zillion out there on the road.
I'd be more concerned about the house and if you're wanting a DP, which is a different animal, than a gas puller.
Nothing wrong with a FL chassis either, but when you say it's a plus, what are you comparing it to?
You haven't spoken of your budget and must haves, which has everything to do with the many choices out there.
