Harvard
Sep 15, 2014Explorer
ScottG wrote:
I would look to see if the neutral and hot are swapped in your RV's panel. Or that the ground wires is loose on your chassis or RV panel.
That again, would require 2 faults:
Fault 1) H and N are Swapped
Fault 2) An open Ground
Remember we have a "Hot Skin" to EARTH voltage of 50VAC, so Fault 2 is a stand alone fault that anyone can demonstrate by having any 3 wire 120 VAC device that lacks 3rd wire continuity. In all cases there will be a measureable AC voltage from the floating CHASSIS/FRAME/KETTLE to EARTH in a other wise proper installation.
I am not suggesting that we cannot have more then one fault, I am suggesting in all likelihood there is only one fault.
38,769 PostsLatest Activity: Dec 31, 2014
