Harvard
Sep 16, 2014Explorer
rforehand wrote:
getting zero volts GFCI GROUND OUTLET to EARTH GROUND.
Also getting zero volts from door frame to EARTH GROUND.
And this is what you should be getting when there is no "open ground".
BUT
It does not verify the validity of the CFCI NEUTRAL to GFCI GROUND at ~ 2.0 VAC.
A GFCI NEUTRAL VAC to either EARTH GROUND or GFCI GROUND should be the same, AND, 0.8 VAC is more realistic then was the ~2.0VAC reported earlier.
Can you recheck your work?
38,769 PostsLatest Activity: Apr 24, 2002
