Slowbob
Jul 13, 2016Explorer
OLYLEN wrote:
Any inverter/converter combo I have seen has a flow through of two 20 amp breakers, but does not need to have the inverter on to have 120 flow through. On 30 amp hookups I go by a rule of three. Sometimes you can get away with three thing on, but most of the time only two before a 120 problem, breakers.
LEN
Then you haven't seen ours. Like the man said, some systems require the inverter to be ON (not inverting, just not off) to flow AC to the coach. Ours operates just like that. If our Trace 2500 is OFF, then every AC outlet in the coach is dead. I'm going to fix that, but that's the way Monaco built it in 2003, so I really doubt that it is unique.
Bob
Full time in our 2003 Monaco Exec 43 DSSD ISM
