ron_dittmer
Feb 09, 2021Explorer III
Many years ago, I got into comparing the specs of the Ford E350/E450 and the Chevy 3500/4500 chassis.
Comparing frames of the E350 to the E450, the gauge thickness of the E450 frame it a tab bit thicker than the E350 but is otherwise dimensionally identical. At a glance, you don't see a difference, but you can measure the difference with a calipers.
I recall the frame of the Chevy/GM is dimensionally smaller than the Ford, and it is significant. I don't know if GM uses a different type of steel to achieve it's GVWR, but I always wondered about the stability of it's physically smaller frame. Given everything else identical, a physically bigger frame would have less frame twist over uneven surfaces. Less twist means the house is better protected from seams breaching.
