dalefuji's avatar
dalefuji
6 volt batteries in series
I have two 6-volt batteries wired in series. If I understand this right, this gives me 12 volts and 100 amp. If I had two 12-volt batteries wired in parallel I would have 200 amps.
Can I switch to 2@ 12 volt batteries without problems with the power inverter or do I have to change or upgrade power inverter.
  • The Trojan J150 is a 12 volt true deep cycle battery for you to consider. 150 AH
    http://www.trojanbattery.com/pdf/datasheets/J150_Trojan_Data_Sheets.pdf
  • BTW Look up the specs for your 6V batteries.
    Look up the specs for the 12V batteries you want to buy. Most likely they will not have a Ah rating but a CCA as they are starting batteries.
    Nothing wrong/right with your proposal but rather the two are not equivalent considering capability and cost.
  • Most 6V GC batteries used in RVs are 230A giving you 12V at 230Ah. Most 12V RV batteries are about 80Ah giving you 160Ah. Marine deep cycle batteries are a compromise and not much better than starting batteries.
    You can switch to 12V batteries. Battery terminals and cable may be different.
    You can buy 12V deep cycle batteries but they are expensive and they are NOT marine batteries.
