- Use a 12 volt Battery Tender brand charger. Get a Trik-L-Start combiner if you chassis battery does not already charge from the converter.
Fully charged lowers the freezing point to about -90F - bshpilotExplorer
JimM68 wrote:
A fully charged battery cannot freeze in temperatures found on earth.
A discharged battery can freeze, because the electrolyte has basically turned to water.
learn something new every day ! thanks !
i guess all those years in cold climates i got lucky and never had a discharged battery. - JimM68ExplorerA fully charged battery cannot freeze in temperatures found on earth.
A discharged battery can freeze, because the electrolyte has basically turned to water. - bshpilotExplorerhow will a battery tender (charge maintainer) prevent a battery from freezing ??
Ive used battery minder/tenders for year and am not aware of them having any capability of "heating" a battery to prevent freezing (as the OP says he's looking for). - wa8yxmExplorer IIIConsider the following statement, Then I will explain it, and then I will answer your question:
1: There are NO SIX VOLT BATTERIES in RV, only 12 volts.
2: For ease of handling and some other reasons (Cost) some of those 12 volt batteries are 2-piece units (Each piece is six volt).
3: Yes
Just hook the six volt pairs in series, as they are when in use, and you have an instant 12 volt battery, Every auto store from here to there and back again including Batteries Plus stores and many department stores sells 12 volt battery tenders.
And your 12 volt bat-t-ery will work just fine with one (That is a 12 volt battery split into two pieces with a jumper cable in the middle) - MrWizardModeratorYour sixes are wired as 12's
Any 12v battery tender/minder will do the job - sch911ExplorerAssuming you're running you 6V batteries in series (12V) like everyone else any 12V maintainer would work.
- gboppExplorer
38,707 PostsLatest Activity: Feb 28, 2025
