D WILSON wrote:
I DON'T HAVE POWER TO THE TAIL LIGHT PIN ON THE 7 PIN TOEING CONNECTOR ON THE REAR OF MY RV. ALL OF THE OTHER PINS WORK , BREAK LIGHTS , RIGHT TURN , LEFT TURN,& FLASHERS. IS THE 7 PIN CONNECTOR FUSED IN ANY WAY? AND IF SO WHERE ARE THE FUSSES FOR THE 7 PIN ?
ANY & ALL INPUT WOULD BE GREATLY APPRECIATED !!!
Well Sir,
It would be nice to know what make/model/year/chassis/engine you have so there could be more accurate answers. You see, yes, in some cases, the 7-pin connector is powered up by a totally separate set of fuses, SEPERATE from the ones that power the tail lights. Freightliner does this for most of its diesels. On our coach, an '04 Itasca Horizon 36GD with the CAT C-7 330HP, the fuses for the 7-pin connector are located in a weather tight box, inside the left rear louvered panel. It lifts up just like a compartment door only, it's held in place with screws.
So, this is why we need to know the info asked above.
Scott
