Johnny_Dearborn
Sep 11, 2013Explorer
$700 Later, Leaky Shower Drain Fixed
While on my road trip to North Dakota, I noticed a little drop of water on the outside of the coach coming from the area near the shower. On returning home, I had the guys at RV Specialists in San Diego take a look at it.
Turns out, that when I stood in the shower, that caused the tub floor to flex downward. That applied pressure to the drain pipe below which then caused it to leak at a joint. The water then went who knows where which explains why there's been a musty smell in my RV as of late.
They reinforced the floor and repaired the leak so the problem was solved. (There went the budget for my new Bilstein shocks though.) They did say that this is a common problem among many RV's. Many of the new ones especially use a hardened styrofoam glued to the bottom of the tub to support it. Over time, it compresses and then a leak eventually appears.
Just something to think about. Might be worth slotting in a helper 2x4 before it becomes a problem.
