ArchHoagland wrote:
crawford wrote:
ArchHoagland wrote:
Did the main engine fan clutch engage which produces a very loud roar?
When on high way fan isn't needed so clutch fan isn't the problem. Poor water flow between water pump or radiator or head gasket problem.
Hmmmm... Come on out west and climb a few mountains at 95 degrees and I'll guarantee you need the engine fan clutch to engage on an 8.1 engine.
Do you have an 8.1 engine?
so what you say once water temp goes down to it's coolest point you think the fan is going to cool the the engine some more Your probably one's who also think taking out thermostats make them run cooler to....
