noleakman wrote:
How do you know when you have this problem? Before it blows!
You are talking about a problem that shows up very very seldom considering there are tens of thousands of the 8.1L engines out there. You can add various gauges to your coach to monitor all kinds of things. Some travel with an OBDII gauge hooked up constantly and they may monitor the air/fuel(A/F) ratio and the LF1 & 2 which are the fuel trims. These can tell you if anything is going on outside of the normal parameters that may indicate a problem in the making. To do that, you have to know your engine and know what the "normal" is.
Any engine can have a problem at any time, diesel or gas, Ford or GM. You can go crazy and spend a lot of money to install equipment to monitor everything. Your best course of action is that if something doesn't feel right, get it checked out. If the oil light comes on when trying to exceed 3500 RPM, you have a problem that needs to be corrected. Sensors can and do fail on any engine and anything that is going on that does not seem normal needs to be checked out. The problem is finding a qualified mechanic that knows how to actually troubleshoot a problem instead of just throwing parts at your coach and hoping that one of them corrects the problem.
