Newbiecampers
Jan 30, 2018Explorer
fugawi wrote:
Are there any other manufacturers with this layout? I haven't seen them in my research.
We have a Coachmen Freelander 21qb. Similar to that 23U layout except minus the small chair by the entrance. But the coachmen has a nice large u-shaped dinnette that when made into a bed, can easily accomodate an adult-sized person. Rear bed is 60X80. Front overhang bed is also large.
Nice 50 gallon water supply. I added a second battery as well.
Looking at the floorplan you posted, the 21qb has a larger closet inside, by almost double.
Only 23'10". We drove this around on our last vacation and were able to get anywhere we wanted. We even scored a beautiful camping spot, with no reservations, in Glacier due to it's smaller size. A particular area of a campground there was hard-side units only due to bear activity, and further, the campers could not be more than 24 feet total length. We practically had the place to ourselves, except for a few other 24 ft class C's and some people pulling teardrop trailers. Getting into/around small gas-stations or parking lots: no problem. etc. etc.
No slide (which is what we wanted for the same reasons as most other people that don't want one).
Cargo capacity is 4500 pounds. All tanks full (water, fuel, propane, waste tanks) plus all of us and our stuff and we were still close to 2000 pounds under max.
The rear outside storage is massive for a class c this size. And the side door for the area is large enough to get big items in if you need.
It is, however, a more budget-minded camper. It lacks some features like: no radio in the cabin, not even speakers (none outside either), only a 2 way refrigerator vs 3 way, gas only water heater (but heats very fast), non-ducted air conditioning (can be loud), tpo roof vs fiberglass, etc..
Build quality is on par with what the rest of the rv industry is putting out: lacking in many respects. It is definitely no better, but certainly no worse than most others. We put 7000 miles on it over 19 days starting the day after we bought it and everything worked/nothing failed on us. Definitely some warranty issues to be fixed come spring.
