Mudshovel
May 15, 2013Explorer
Jimmymac603 wrote:
Mudshovel, Here's a pic of the cabin's power connector. Been trying to find a female connector for the 4=prong twist to a 3 prong standard 30amp connector. Can't find it anywhere. I have to step up to 50amp then convert to 30amp standard to the 3-prong. A lot of "dogbones" or adapters to connect into a campground 3 prong 30amp shoreline service.
4-prong twist cabin connector
If you have any ideas, I'm all ears! Thanks
Well that connector is a 30amp found on things like welders compressors etc, used with 220 Volt, we use them around the shop. You can get a female end from home depot, but I recomend converting to use with standard 25amp service plug that most (all?) rv parks use and get a adaptor to 15amp house plug for when your at home etc.
The 25amp rv connection is what you want, seems funny that somebody put that one on your RV, like I said before that's used with 220v service thats why there are 4 prongs, 2 110 load, 1 common and 1 ground. I can post a picture tonight of mine, very easy to change.
38,780 PostsLatest Activity: Jul 04, 2015
