Mudshovel
Sep 04, 2013Explorer
81shastaboy wrote:
Also have a 81 Shasta with 64k on it is a e350 460 c6 my modle is the 25rd it has two table two bunks over the cab and over the bed in the back i had a little fire in the back were the gen sits the exust
pipe got bent up and started floor and the wall on fire . now i have
to replace the paneling and some timbers some sheet meatal.
there not to many on the road old ones
don
Well sounds like you got the fire out quickly and you and your MH are ok. I've always wondered about high temps of the genset and fear fire. My genset has over a 1000 hrs on it and has a layer of dirt and greese about 1/8 thick. going to power wash that off and remove flywheel cover and cylinder head heat shield and get that all cleaned out to reduce operating temps. I have found many RV's missing heat shielding on the genset exhaust, like mine I think that they rattle off and don't get put back on, it is a tight hole to work in.
On the fire note I also fear the fridge, seems to be alot of them burning up RV's so I've read and see video's.
And you are correct, I have not found very many old Shasta MH's really the only ones I can pull up on internet searches is mine. And have never found one exactly or close to mine.
And I've never see one with wings like mine had wich I researched as a rare and unwanted option. lol
38,782 PostsLatest Activity: Sep 10, 2026
