MrWizard
Oct 06, 2011Moderator
Dometic leveler , re-branded A&E
HWH has springs if you need them
The 12v solenoids etc.. are standard hydraulic parts
Any good commercial hyd shop can repair the cylinders
There are even work around rewireing methods if the control board is bad
I always used manual leveling for the one we had because automatic always put us higher off the ground than doing it manually
I liked that system more than the one on this RV
