Old-Biscuit
Dec 03, 2016Explorer III
IF that 'hot water tank' is a conventional rv water heater (suburban/atwood) then you drain it by removing drain plug and open a faucet hotside to allow air in
Drain plug is in outside compartment under burner tube.
Suburban drain plug will also be an anode rod so you unscrew it and remove the whole assembly
Atwood would have a Nylon drain plug only
Course who knows what previous owners have done ....modifications made???
Can't help on front springs
38,763 PostsLatest Activity: Dec 05, 2025
