n7bsn
Apr 12, 2016Explorer
kuziwk wrote:
Would it be safe to tie a battery or two in line with the solar panel charger as this would be the easiest...than this would hookup to the battery under the hood and all the batteries would equalize with each other?
The battery under the hood (engine) should -not- be a gel-cell. The vehicle charging system could wreck a gel-cell.
You can't hook regular/AGM batteries and gel-cells together, it just doesn't work.
What kind of regulator is on the solar charger? One for regular/AGM?, if so, you really shouldn't used it to charge your gel-cells.
38,782 PostsLatest Activity: Sep 02, 2026
