wolfhunter wrote:
1492, I'm a slow learner, Is RV.NET the same as irv2?
Hi,
1492 is a Moderator, and he moved your post to Class A RV's. He expects more interest there, and the question has more to do with Class A motorhomes, than questions about how a computer works.
RV.Net is not the same as I RV 2.
I have no idea what you are describing, but it might be a power steering unit? Sometimes the brakes are connected to the power steering unit, but I would rather be using the vacuum booster that tends to work so well with a gas engine. If the fluid is red or yellow, then it likely is power steering or with a hydroboost will do both power steering and power brakes.
Good luck!
Fred.
