Garry_Bujak's avatar
Garry_Bujak
89 Ford E 350 fuel problems
I have a 1989 Ford Jamboree E350 26 foot with a 460 motor having fuel problems three times now the first time it ran for about 70 miles and fuel failed I have so far replace the ICM ignition control module (costly)and fuel filter I can hear the pump running. but engine runs out of gas. In cooler weather it didn't take long for it to start back up and run great for a few more miles then failure again as the days have warmed the failure resulted faster
Thinking it was probably the fuel pumps I began reading here on rv.net and it may be the fuel pump relay switches are they more susceptible to failure on the ambient temperature my unit has two fuel pumps one inside the tank as a primer pump for the high pressure pump that's mounted on the frame just below driver seat my first question is, will there be two relay fuel pump relay switches or one? I know there are several people out there that have these units the Ford 460 is very popular has anyone ever experienced anything like this I need help before I start replacing each pump & relay switch one by one till I find the problem. This has been a very aggravating adventure. Our rv only has 39k miles an is in excellent condition for an 89 model.
