uwireme's avatar
uwireme
91 Pace Arrow auxiliary switch
I was driving my 91 pace arrow when the motor just shut off.
The only way I could start the motor was to push the auxiliary battery switch.
The batteries are good but the house battery disconnect switch above front door does not work.
Any help would be great.
  • I have four-6 volt batteries and one 12 volt
    I read a little over 12 volts for both sets
    Does someone have a wiring diagram to wire the 4-6 volt batteries for the house and the 12 volt for the engine?
  • Bad alternator or battery.
    If the engine continues to run after immediately releasing the aux start button, the battery is bad. If it dies, then the alternator is bad and possibly the battery.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Check the chassis battery and alternator. I had a similar episode in a car once. The alternator had died so the spark plugs were getting their power from the battery. When the battery ran down, the engine died.
    Is this issue a "new" issue, as in one that just started when the engine quit or one that's been there for awhile?..:h...Dennis
