dougrainer
Aug 02, 2013Nomad
Your year model requires the Gen set to operate the rear AIR if you need BOTH AC units to run. Your Fleetwood(as well as most others from your year), the Genset has 2 breakers on it. A 30 amp main breaker which obviously is ON and the second breaker which will be either a 20 or 30. THAT 2nd breaker is dedicated to the REAR AC on your unit. Make sure that 2nd breaker on the Genset is ON. The odds are that 2nd breaker is OFF. Doug
38,769 PostsLatest Activity: Apr 03, 2026
